***help***
Old Jan 7, 2012 | 09:26 PM
BOOMER2011's Avatar
***help***
where is a place under the hood that gets 12vs of power ONLY when the truck is CRANKED?? i need to have a place to hook up to power the fans i have. it says attach it to my ignition switch but the only place i know where that is is in the steering column and i am NOT in a mood to tear that apart again
so i guess my question where is another place i can hook up too that will give my fans power for only when the truck is cranked?
Old Jan 7, 2012 | 10:22 PM
Raptor05121's Avatar
The starter solenoid on 99+ trucks, one side should be ignition only (key is ON, doesnt matter if engine is running). But then again pin 71 and 97 on the grey PCM connector are also ignition only.
image courtesy of Patman
Old Jan 7, 2012 | 10:26 PM
BOOMER2011's Avatar
so where is the PCM and what do i need to tap into?
Old Jan 8, 2012 | 12:00 AM
Bluegrass's Avatar
A quick way to get switched power is do a fuse "add a tap" attachement at the fuse panel under the dash on a fuse the supplies power only when the igniton is in run, not acc.
Get the correct size fuse tap to fit the small fuse size used, to feed a second slave circuit.
The slave relay will have one side of it's winding grounded and feed the other side from the fuse tap..
Use the second tap to feed a slave relay so you don't overload the tapped circuit.
Feed fused power 'at the battery' to the slave relay to supply power to your fan equipment.
Size all fuses and use correct size wire for each application and do the work so it has reliability and is safe..
Good luck.
Old Jan 8, 2012 | 02:10 AM
BOOMER2011's Avatar
Is that something I can pick up at autozone or orileys auto parts ?
Old Jan 8, 2012 | 08:29 AM
BLUE20004X4's Avatar
I tapped into the fuse box underhood in a unused spot, a spade connector fit I believe. You can get them anywhere yes, that sells connectors.
Old Jan 8, 2012 | 12:01 PM
BOOMER2011's Avatar
do you remember which one it was you tapped into
Old Jan 8, 2012 | 02:09 PM
BOOMER2011's Avatar
all is good have them mounted a runnin like champs, when they spin up they sound like a jet engine haha
Old Jan 8, 2012 | 02:13 PM
str8t six's Avatar
what brand fans are you running?
Old Jan 8, 2012 | 03:50 PM
BOOMER2011's Avatar
TCI it's one of the company's the company my dad works for owns, got em do free
Old Jan 9, 2012 | 02:55 PM
03Fx4JD's Avatar
shoot can ya get more for that price? haha...
