wet spark plug whats going on
Old Dec 29, 2011 | 04:04 PM
aaron1998f150's Avatar
Exclamation wet spark plug whats going on
so i found a wet spark plung in my truck wat does it mean
Old Dec 29, 2011 | 04:08 PM
Thread moved from the 2009-2012 forum
Old Dec 29, 2011 | 04:17 PM
woops dident noticed i posted on that thread
Old Dec 29, 2011 | 05:11 PM
Which cylinder was it pulled from and what is the wet stuff?
Did you check the plug well before pulling the plug?
Old Dec 29, 2011 | 06:58 PM
Yea it was wet with water and rust and the 8cylinder
Old Dec 29, 2011 | 07:42 PM
str8t six's Avatar
it was on the drivers side?
Old Dec 29, 2011 | 09:45 PM
Well, you have some kind of water leak into the #8 well........
Old Dec 29, 2011 | 10:28 PM
yup driver side and i found 3 more on the passenger side i took them out a with and air hose bleew out the water put some grease in the spark plug wire socket and it solved the problem for know
Old Dec 29, 2011 | 10:51 PM
jethat's Avatar
I would look at the rubber wheel well skirt and see if its come undone. There is really not a way for water to get on that side unless its outdoors water or road water.. Car wash? on the paassenger side you can have the heater hose leaking..
Old Dec 29, 2011 | 11:26 PM
I think its the car wash after that I noticed it started messing up
Old Dec 30, 2011 | 04:33 AM
What did you do - wash the engine?
Old Dec 30, 2011 | 11:29 AM
no i never do that
Old Dec 30, 2011 | 12:29 PM
str8t six's Avatar
thats what i was thinking. most trucks have water on the #4 cylinder from the heater hose.
Old Dec 30, 2011 | 03:46 PM
Yea I checked those spark plugs to only one was wet there too
Old Dec 31, 2011 | 02:41 PM
projectgt's Avatar
Coolant maybe?
