Str8t six's Lightning swap thread
Old Dec 25, 2011 | 12:09 AM
  #31
GATOR CREW's Avatar
2009 F150online Truck of the Year
very nice!!!!
Old Dec 25, 2011 | 12:16 AM
  #32
lltoolj's Avatar
Nice work! that vid is just a tease...
Old Dec 25, 2011 | 12:18 AM
  #33
str8t six's Avatar
thanks!
that video is only for the datalog that you have to do when you are first tuning a vehicle.
i cant drive it just yet. later this week i will tho!
Old Dec 25, 2011 | 12:24 AM
  #34
GATOR CREW's Avatar
So where did you pick up the Eaton from?
Old Dec 25, 2011 | 12:27 AM
  #35
str8t six's Avatar
i got it from a guy in texas 3 years ago when fordtruckworld was still active
Old Dec 25, 2011 | 12:29 AM
  #36
GATOR CREW's Avatar
WOW!!! So you finally decided to put it on after 3 years huh??? ROFL!!!!!
Old Dec 25, 2011 | 12:35 AM
  #37
str8t six's Avatar
i got it when i first joined the military, then i moved and never had a place or time to put it on.
Old Dec 25, 2011 | 05:52 PM
  #38
GATOR CREW's Avatar
o ok
Old Dec 25, 2011 | 09:04 PM
  #39
mxr181's Avatar
I think you are missing the little aluminum spacer you are sopposed to have from MAD to use the LFP lower quick change with the stock NA harmonic balancer...it obviously still bolts up but according to Mike you still need that little aluminum spacer
  #40
mxr181's Avatar
looking great though!
Also if you havent already gotten a water pump I would get a NAVI water pump...I got it with the spacer from MAD and mike truck stays right at 170 (he also reccomended a 170 degree thermostat) with a stock radiator.
Old Dec 26, 2011 | 10:47 PM
  #41
coobies5's Avatar
hell yeah!
Old Dec 29, 2011 | 06:55 PM
  #42
Dinggus's Avatar
Do you have to replace the transmission as well when do swap in the supercharger?
Old Dec 29, 2011 | 07:32 PM
  #43
str8t six's Avatar
no you dont have to. you can use the 4r70 but I would atleast get a shift kit and a larger cooler for it. then start saving up for a rebuild.
Old Dec 29, 2011 | 10:42 PM
  #44
lltoolj's Avatar
any updates?
Old Dec 29, 2011 | 10:44 PM
  #45
str8t six's Avatar
i got it running and all, i had a problem with a supplier and i dont have a spacer for the mechanical clutch fan yet. it should be in tommorrow or saturday so i can go for a test drive.
