Low Beam HL, Brake Lights, Odometer, etc not working
Old Dec 1, 2011 | 11:54 PM
ZTegels's Avatar
1997 ford f-150, 4.6 L, Automatic
Running into an issue with multiple components not working:
Odometer
Speedometer
Low Beam HL
Brake Lights
Fog Lights
Turn Signals
Hazard
Truck sometimes has issues starting or stumbles when running if I hit a bump, hit the steering wheel or even slam a door.
Fuses 16, 20, 21, 26, 27 and 28 have no power to either side (fuse box inside the cab, test light used to check). Fuses are good as near as I can tell. All of the fuses in the power distribution box under the hood are good. I recently replaced the GEM in this vehicle when this problem occured - I pulled it back out an double checked every connection and everything looked ok. I also replaced the MFS/turn signal thing.
Could the blue flasher relay under the dash be causing an issue? Any other thoughts/ideas of things to look at?
Thanks for the help in advance
Zack
Old Dec 2, 2011 | 05:47 PM
madturtle66's Avatar
electrical issue
I have the opposite problem with my '02 screw, everything works except i have no tail lights. Hoping to catch a remedy here before i have to take it to a shop.
Old Dec 2, 2011 | 10:05 PM
Raptor05121's Avatar
Post in the electrical section for a better chance of diagnosis.
Old Dec 3, 2011 | 12:49 AM
ZTegels's Avatar
Brake Switch
Hi MadTurtle -
It might be your brake sensor (if none of your brake lights work). It's a 13 dollar part at Ford. This is a small black sensor about the size of a zippo on the brake pedal lever. Pull out the cotter pin and move everything off the post. Unplug the sensor and replace it with a new one.
I am not sure what fuse would be the one controlling the brake lights, but I would check the owners manual and take a look at those with a test light too.
I know the brake sensors can be an issue and I need to check mine tomorrow for good measure.
Good luck
