Project "Big Red"
Alright what's your opinion on tail lights from there? And well I've decided to save up and wait until probably after christmas, and purchase new rims and tires same size.
I've got 245/70/R16 on the back theatre all season in good shape, the front tires need replaced so I'm thinking about putting them on the front and putting 255/70/R16 winter studded on the back, if I post a picture can I get an opinion? Not sure if the tires are still good
The led tails are decent I guess, they're not as bright as you'll expect them to be and you'll need a tridon ep27 flasher relay to fix hyperflash on your turn signals once you get them. But I wouldn't pay the prices that website you were talking about earlier wanted, whether you pay 30 or 130 for them, they're all the same.
It's when your turn signals flash fast as if a bulb is out. I put LED bulbs in my front corners and got hyperflash. So I had to install a load resistor on each on.. and problem solved. Now they flash normally
When I asked my Napa store about an LED flasher relay, I was told it was not in stock but around 40 buck. How much is/was the EP27? Load resistors were $8.00 each
Nice rig to start with but 245 isn't wide enough for the front...get 265/75/16s at all four corners and you will have a great looking setup. 285s will fit(they'll look ballooned) the rims only if they aren't low profile and you would need 1/4" wheel spacers to clear in the front.
As everyone else said, those projectors are the worst things ever produced for our trucks. There are much better deals out there, I got my smoked heads for 200 delivered to my front door w/ 55watt hids and led turn signals. The real problem with those spyder halo headlights is that they tried to go to a 1 piece setup and it just don't fit right.
as far as tailights, smoke the stockers.
