Please help
Please help
I tested my blower motor by runing wires straight to the battery, smelled like something was burning so I unpluged it and turned the truck off...NOW I have no power to windows, interior lights, wipers, and I have no idea whats wrong. I looked for bad fuses, relays, burnt wires...found nothing
If you did not disconnect the blower before testing, oh well.
A blower can take more than 20 amps on high speed so your test wireing may have started to melt the wire insulation.
As stated, te GEM controlls all the functions you are now missing.
Good luck.
Good luck.
THANKS! @ BLUEGRASS...The motor was ran from battery to blower alone nothing else was pluged in but I messed up by not putting a fuse in the line...I used 10g wire so it was not that burnig. Something on the drivers side was burning so I was about to pull the fuse panel out a few minutes ago but decided to check online first.
I appreciate the info guys! I was about to hunt for burnt wires but now I have a feeling it may just be the GEM. THANKS! Im gunna go pull its out now & checkit
