Need help
Old Nov 11, 2011 | 01:23 PM
GOGLU's Avatar
Need help
I have a 2002 ford f-150 v-6 i only get cold air from the heather can someone help me out? I think it may be the thermostat but i don't know where it is. Is it hard to replace?
Old Nov 11, 2011 | 04:12 PM
Bushwhacker's Avatar
Have you checked the water level in the rad? Water has to be right up. Thermostat would make it overheat rather than stay cold. Is it frozen? Is there any antifreeze in it? Many questions.
Old Nov 11, 2011 | 05:23 PM
A thermostat that's stuck OPEN will make it stay cold. What does your temperature gauge read - is it in the middle where it normally should be? If so, your thermostat is working well enough to give you some heat.
Old Nov 12, 2011 | 01:43 PM
Volvit's Avatar
Also check the heater blend door actuator to make sure it's switching from hot to cold. I've replaced a few.
