4.6 Plug Change
Old Oct 26, 2011 | 10:46 PM
holler1's Avatar
Originally Posted by coobies5
i guess my posts aren't showing up or something, because i've already explained what you need to do......
Coobies5,
I apologize - my mistake. I did read your posts, but when I first looked at your picture, I didn't think the insert was the same as mine. I went back and looked at it again, and I do see the similarity now. My concern about putting the same type of insert back in is that when I took mine out, it didn't come out clean and it appeared to bring some head material along with it. I'm thinking if I put one like that back in, the hole may now be oversized for it. So that's why I was considering putting a TimeSert in. Over the next few days I'm going to check the other cylinders to see if there are any other inserts in the engine. Then I'll decide how to fix #5.
I did look at Advance Auto and the ones they sold didn't look like that one. Now that I have the insert separated from the plug, I might take it around to a couple of stores and see if I can find one like it. We don't have an O"Reillys in this area.
Old Oct 26, 2011 | 11:16 PM
coobies5's Avatar
Originally Posted by holler1
Coobies5,
don't worry about it, it's all good, just trying to help when i can.
if that insert brought out some head material, i'd get a shop to look at it and possibly weld new material in it and tap it out to fit a new insert.
Old Oct 27, 2011 | 12:53 AM
Originally Posted by RobD
My manual says [2002 and earlier models spark plug torque 84-168 in lbs] 168 = 14FT LBS [2003 AND 2004 models 15 ftlbs] I just did mine a few days ago and torqued them 14ftlbs. If someone knows something this manual doesn't please elaborate.
Get back in there and retorque them to 28 ft/lb or you are risking loosening and blowout.
http://blownoutsparkplug.com/faqs.htm
Read #51 and #52.
Old Oct 27, 2011 | 02:07 PM
RobD's Avatar
Read #51 and #52.
Thank you , Will go do it now.
