Need body lift help!!!
Old Oct 26, 2011 | 10:29 PM
Alex Laird's Avatar
Unhappy Need body lift help!!!
Body lift is on my truck everything is awesome and I love the look of it but I have one major problem... It wont shift!! I put that bracket that came with the PA 3" BL and hooked it up to the stock bracket and I try and turn it over and it wont start.. I move the shifter on the side of the tranny to Neutral and it starts, but still wont shift. I removed the stock bracket from the PA extension bracket and am able to shift but its not shifting to every gear. I have no idea what is going on and need help asap! Thanks in advanced.
Old Oct 26, 2011 | 10:36 PM
Buxton91's Avatar
Try this:
https://www.f150online.com/forums/ar...inter-fix.html
Old Oct 26, 2011 | 10:55 PM
Alex Laird's Avatar
Ok ill give that a shot right now. Its wayyy off. I just started it and "R" is neutral and the "P" is reverse and it wont even shift down to first. You think this will fix that problem?
Old Oct 26, 2011 | 11:00 PM
Alex Laird's Avatar
I just tried that and that didnt fix my problem. I have no idea what i need to do
Old Oct 27, 2011 | 12:38 AM
Toyz's Avatar
You must have bumped the linkage out. I did that when I was doing my swap. Youll have to manually put it in park at the linkage.
Old Oct 27, 2011 | 03:57 PM
Alex Laird's Avatar
Ok ill try that when I get off work. I was messing with it for a couple hours last night and couldn't figure it out
