New Ignition lock
Old Aug 28, 2011 | 10:13 PM
fordforce39's Avatar
New Ignition lock
Key has been getting stuck in ignition won't turn to start truck. Need to replace cylinder, found out it has PATS systems.
I have one good key, can i buy a new lock with two keys and tape the
old key up under the steering wheel somewhere to trick the truck into
starting?
What's a usual fee for a locksmith to come out and program the two keys?
Old Sep 29, 2011 | 01:26 PM
KyJim's Avatar
I am having problems with my dome light staying and the door dinger has something to do with ignition cylinder maybe a loose wire not sure , if you move the cylinder the door dinger will stop . I have been removing the fuse it shuts off the dinger the dome light also the wipers and the electric windows . would like to solve the problem any ideas out there .
Old Sep 29, 2011 | 01:46 PM
PirateSignal's Avatar
starting?
I was told at the Ford Parts counter that only Ford can program the PATS, as only they have the codes (not sure if this is correct, but seems to make sense).
