1997-1999 4.2L interchangeability
Old Jun 7, 2011 | 10:13 AM
jlbennett's Avatar
I have a 1997 4.2L 4 speed manual with a bent rod and have an opportunity to purchase a 1997 4.2L auto-are they interchangeable? What about going from the autotrans to my 4 speed-ie, bell housing, flywheel etc.? Any info will be greatly appreciated.
Old Jun 7, 2011 | 10:34 AM
Raptor05121's Avatar
They are interchangeable.
Old Jun 7, 2011 | 11:32 AM
4 speed? The only manual I'm aware of in a 97 F-150 is a 5 speed M5OD-R2.
I would not recommend buying a 4.2 engine with a build date earlier than 1/16/98 due to the gasket and hydrolock issues. In fact, that's how you probably bent your rod.
Old Jun 9, 2011 | 12:58 PM
Bilster's Avatar
Or get the intake gaskets replaced before installation. It's the intake gaskets before the 1/16/98 build date that caused the hydrolock problems.
Old Jun 9, 2011 | 11:42 PM
Specifically, the lower intake gasket and the front cover gasket.
Old Jun 13, 2011 | 03:00 PM
jlbennett's Avatar
Thanks all for the info-you are correct as to the cause of my woes. JLB You are correct-it is a 5 speed.
