exhaust rattles
Old May 25, 2011 | 02:37 PM
rcxford617's Avatar
exhaust rattles
i had obx long tube headers hi flow cats installed a whhile ago. well soon when going through the drive thru at mcds i realized theres a rattling sound and at first i was ok with it but now its annoying and when i get on the gas i can hear air its like my throttle is connected to my ac which ticks me off cause i paid 400 for the instalation i know its a exhaust leak i just gotta figure out where... any idea on the rattling noise???
Old May 25, 2011 | 03:02 PM
rcxford617's Avatar
went outside after posting this and lstened to it to try and give a more in depth description. it seems to be on the passenger side i cant really hear it on the drivers side, the rattling seems to be louder from the cats to the tips than from the headers down. and also are there any tricks to pinpoint a exhaust leak besides listening
Old May 25, 2011 | 03:45 PM
ford4life.'s Avatar
check your cat sheilds thats where mine rattles at
Old May 25, 2011 | 04:06 PM
2000FORDMAN's Avatar
Try to hover your hand around where you think the leak is, if you feel hot air, you found it.
Old May 27, 2011 | 04:02 PM
jbrew's Avatar
Micky D Drive thru chirping is the cat shields. Wrap a couple 7 or 8" band clamps around the converter to temporarily take care of it. If you have a welder, -a little Mig would work, you can position the tip of the gun at the converter seams then at a 45 degree angle w/the mig wire cut back flush to the tip. Pull the trigger for exactly 2 seconds, let go, reposition every 4 - 6", - then same deal, pull for 2 seconds, -move on.
That's if you want more of a permanent fix, -better spot welds.
_____________________
Use a small shop vac and squirt bottle w/a little dish soap to check for leaks cold. Blower mode, shove it up your tail pipe, then hose down your seams w/soapy water. If it's leaking, you'll know it via Mr Bubbles.
You can used compressed air at about 15 lbs to pressurize check as well. It doesn't take much effort this way and you can definitely confirm how bad the leak is and where.
Good Luck.
Old May 28, 2011 | 03:51 PM
rcxford617's Avatar
thanks guys i read a old post that said about the clamps so sorry about wasting yalls time and sorry it took so long to respond ive been teaching a kids camp for the summer. ill try the clamps till i can get it to my friends to welld it thanks again
Old May 29, 2011 | 04:53 PM
rcxford617's Avatar
anyone have a link to those clamps?? ive looked aand i cant find them
