Efans help
Old Apr 23, 2011 | 04:23 AM
cstritz's Avatar
Efans help
Alright so i got my leveling kit on and will be saving up to get a body lift and some new tires at the same time but meanwhile i would like to look into efans since most people seem to believe they make quite a big difference in performance and mpg. I will not however pay the 400-500 dollars for a kit because that's just ridiculous. What exactly are all the components i would need for my own custom setup? And please feel free to leave any suggestions of certain items. Im looking to keep it under $200 if possible. Thank you for all your help!
Old Apr 23, 2011 | 08:56 AM
str8t six's Avatar
All you need is a fan and a controller with a temp sensor. Check out madeneterprise.com for the DIY kit
Old Apr 23, 2011 | 03:34 PM
Bansheeman6100's Avatar
I used the Flexalite controller with a Mark VIII fan, great combo! Havens had an issue other than a blown fuse. The fuse supplied with the controller is a 30amp, replace it with a 40amp and your good to go
Old Apr 23, 2011 | 08:19 PM
Raptor05121's Avatar
2 of these fans- http://cgi.ebay.com/ebaymotors/16-15...Q5fAccessories
this controller- http://www.autopartswarehouse.com/de...e&apwidR2ABX7y
and some strips of aluminum, nuts, bolts, and washers from Lowes.
Old Apr 23, 2011 | 09:07 PM
cstritz's Avatar
the madenterprise kit is about $400 which is what i was trying to stay away from. But thank you for the links raptor05121. Does that controller actually work on our vehicle for sure though? it says its for chrysler imperial?
Old Apr 23, 2011 | 09:18 PM
azmidget91's Avatar
those will last maybe 10,000miles
yes it would work but i would suggest not getting that controller, i went through about 5 of them and about 6 of those cheap ebay fans. get a mark VIII fan and make your own controller our of 5 relays and a temperature sensor from autozone, i did that and have not had a single problem in about 40,000 miles
http://cgi.ebay.com/ebaymotors/Cooli...Q5fAccessories
and here is a thread about making the controller
http://gbodyforum.com/viewtopic.php?t=10001
and autozones temp sensor
http://www.autozone.com/autozone/par...267187_9581_0_
should be able to do it for under $150 easily
Old Apr 23, 2011 | 11:04 PM
its universal. i have the same one on my truck
Yes, you take that chance with any aftermarket part you buy. The ones I bought are ProComps (for the same price) with a lifetime warranty, off an eBay seller. And the controller was $34 from AdvancedAuto. Mine are up to 55,000 miles.
I agree on the $150 part, mine was $130 with everything-
Old Apr 23, 2011 | 11:54 PM
cstritz's Avatar
awesome ok thank you guys. So basically just two 16" fans and a controller then just the custom mounting and wiring.
Old Apr 24, 2011 | 01:34 PM
azmidget91's Avatar
or that single 18" mark viii fan which flows more than the 2 16" fans, and is an OEM part, or take a chance with an aftermarket fan, do a search and see how many have failed, then search for the mark viii fan and see how not one has failed and works great. your choice
Old Apr 24, 2011 | 02:07 PM
x2. some are crap, but most fans are pretty well made. The motors in my ProComps are Bosch motors (also OEM, non-Ford though), but the Mark VIII is a great setup
