e fans
Old Mar 11, 2011 | 05:57 PM
1998f150wes's Avatar
e fans
okay im thinking about getting e fans for my f150 but how much power will they add and mpg (if i keep my foot out of it) 4.6L V8
Old Mar 11, 2011 | 06:20 PM
Bansheeman6100's Avatar
i got about an extra 3-4mpg with that and a Predator combined. i did both at the same time so its hard to tell. definitely worth the time and investment
Old Mar 11, 2011 | 07:06 PM
Midwest Farmer's Avatar
Say i get an electric fan for my 95 5.8, will it hold up doing some offroading now and then?
Old Mar 11, 2011 | 07:30 PM
str8t six's Avatar
Lincoln mark VIII fan, lots of people have them.
Old Mar 11, 2011 | 07:42 PM
Easy to install?
Old Mar 11, 2011 | 07:55 PM
MGDfan's Avatar
Old Mar 11, 2011 | 08:01 PM
i saw a solid 1 to 1.5 mpg gain from doing efans on my 2003 4.6 supercrew
Old Mar 11, 2011 | 08:17 PM
does anyone know the link on how to wire these up two imperials with the auto turn on
Old Mar 11, 2011 | 08:25 PM
MGDfan's Avatar
Sadly, I have NFC what that means, but .... these *may* be pertinent?
http://www.spalusa.com/pdf/fan-pwm-v....PDF#view=FitH
http://www.dccontrol.com/2sp.pdf
http://www.dccontrol.com/fk50p.htm <==< preferred
Something tells me you did not read through those links above, because you would have already found this info...
MGD
Old Mar 11, 2011 | 08:34 PM
thats what im running
Old Mar 12, 2011 | 09:45 AM
And word to the wise: tere are a lot of reports of the 30 amp fuse that comes with the Flexalite controller kit blowing. Mine did lastnight, so I will be purchasing a 40amp today. There's a thread somewhere that is more informative
Old Mar 12, 2011 | 09:52 AM
MGDfan's Avatar
Hmmm .. before doing that, why don't you consult with FAL to confirm the rest of their system can safely tolerate the extra potential draw the 40A would allow?
Best-case - a component failure. Worst-case - a fire.
MGD
Old Mar 12, 2011 | 10:32 AM
shifty_85's Avatar
the Mark 8 fan draws alot of amps on start up i blew a few 15 amps i belive i have a 30 or 40 amp in there now.
saw lots of power gains and 1-2MPG
Old Mar 12, 2011 | 10:51 AM
MGDfan's Avatar
You sure? A True Mark VIII on the high-speed winding, has an inrush north of 80 amps ... one of the main reasons a soft-start controller is beneficial ...
MGD
Old Mar 12, 2011 | 12:40 PM
shifty_85's Avatar
i have mine just hooked up for high and i have a 40 amp inline fuse about 6" from the batt. its been on there for years and hasnt blown since i first blew the 30amp.
