XLT write up PLEASE!!!!!!
Old Feb 25, 2011 | 07:14 PM
ga2wd's Avatar
^yeah true^....all i really want in my truck power-wise is the window and locks...mirrors would be nice but only if they are plug-play.
Old Feb 25, 2011 | 11:55 PM
thejake1989's Avatar
i haz done the conversion. no have all power options (driver seat locks windows and mirrors and keyless)
Old Feb 27, 2011 | 07:53 PM
ga2wd's Avatar
How hard was it to do and how long did it take for you to do it?
Btw I really like what you have done with ur truck jake, keep up the good work
Old Feb 27, 2011 | 08:18 PM
The hard part was running the wires from the passenger door to the otherside.
I got aftermarket kits for the locks windows and keyless.
The locks were easy and take about 2 hrs minus wiring them to the factory door switches. Kit came from ford-power-locks.com and it came with the keyless.
Then the windows took longer since I made my own harness for them to use the factory switches. When I installed them I did the door panel swap also so they took a bit longer and the kit I got off eBay.
Then the mirrors are factory mirrors with factory connectors and switch and all I did was run new wires to connect everything.
It's all powered from my fuzeblock fz1 which is hooked to the battery.
Also thanks man
Old Feb 27, 2011 | 08:24 PM
ga2wd's Avatar
If you don't mind me asking around how much did it cost you
Old Feb 27, 2011 | 08:29 PM
Can't remember what I paid for the door panels switches and mirrors. Somewhere around 100-150 possibly
Then locks were around 70 and windows about 80 I think. Then wire an fuses etc and 70 for the fuzeblock.
Old Feb 27, 2011 | 08:32 PM
ga2wd's Avatar
That ain't to bad...I was thinkin around 500-600
Old Feb 27, 2011 | 09:48 PM
yea it just took time to wire everything up
