headlight switch
Old Feb 26, 2011 | 08:49 PM
Bansheeman6100's Avatar
headlight switch
so i need a new headlight switch. bad. but cant find a decently priced one with fogs. but my factory fogs are gone and the aftermarket ones are hooked up through another switch. so is it possible to use a non-fog switch? i know one of the connectors is different but wasnt sure about the other
Old Feb 26, 2011 | 08:53 PM
jbrew's Avatar
You have choices here -
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Old Feb 26, 2011 | 08:56 PM
Originally Posted by jbrew
DECENTLY priced. most of the ones with fogs get real expensive. trust me, ive been watching
Old Feb 26, 2011 | 08:59 PM
jbrew's Avatar
Well, if you want something for nothin, good luck with that. And post where you have looked, so others don't waste time on you.
Old Feb 26, 2011 | 10:03 PM
ebay, rockauto, and google. i was asking where to find them, i was asking if a non-fog switch woud work since i dont use my factory fogs. but thanks for the super helpful and smart-alec replies
never had that issue with you jbrew
Old Feb 26, 2011 | 10:09 PM
jbrew's Avatar
That's why I gave you a list of what's out there. Any No Problem, I'm using the ignore list feature more and more, - congrats, you made it !
Old Feb 26, 2011 | 10:11 PM
Alexcngford's Avatar
I am currently using a headlight switch that has no fogs on my 2002 xlt. Works just fine i just can't turn on my fog lights with it.
Old Feb 26, 2011 | 11:00 PM
Toyz's Avatar
Check your local craigslists also. There are 2 F150's being parted out in my area. Seem to be common, worth looking anyways.
Old Feb 27, 2011 | 05:40 AM
Thanks Ex, that's what I was looking for. Since there are two plugs in the back I wasn't sure if the one for the headlights themselves were the same or not. And ice been checking there as well Toyz. All but one were non-fog and guy wanted almost what they cost from Ford
Old Feb 27, 2011 | 09:42 AM
Red02FX4's Avatar
one plug is for the dimmer, IIRC.... the other plug for the actual lights
Old Feb 27, 2011 | 09:55 AM
Gotcha. I thought about doing the autolamps thing but think I'll just grab a cheap non-fog switch and be done with it
Old Feb 27, 2011 | 08:32 PM
Red02FX4's Avatar
Yeah... in this pic, left connector is for head/tails/ect. and right connector os the dimmer switch :
Old Feb 27, 2011 | 09:17 PM
Thanks man. It looked like in pics of non-dog switches there were two plugs as well. Not sure. When I get to a computer I'll post a pic if need be
Old Feb 28, 2011 | 01:49 AM
willys5555's Avatar
I had factory switch with no fogs, then got a factory kit to add factory fogs to mine. came with new switch and all wires, and lights. switch was exactly the same as for plugs. then to add fog lights, you splice into one of the existing wires. so yes i would assume it would work in reverse but I didn't do it that way so I am not 100%.
I would find someone parting an f150 out so you can try it for cheap...if my old switch hadnt broken when i took it out, i would be happy to send it to you at the cost of shipping.
