Is my compressor gone?
Old Feb 22, 2011 | 09:07 PM
larbec's Avatar
I have a 1997 F150 4.6 Liter. I think my air conditioner (compressor) is bad, It started to make a rattling noise and then a week later I had no cold air. Does this mean it is bad? How much is a new one (estimated)
Old Feb 22, 2011 | 10:40 PM
jbrew's Avatar
I've seen them for $30 on ebay. -
Look for new take offs. Their removed from crate motors and sold. -
Old Feb 22, 2011 | 10:44 PM
paker's Avatar
Rattling noise is probably from the AC clutch. Check if AC compressor spins.
Old Feb 22, 2011 | 10:46 PM
paker's Avatar
Thanks for the tip.
Old Feb 23, 2011 | 09:55 AM
larbec's Avatar
Thanks, I will check it out
Old Feb 23, 2011 | 02:14 PM
Raptor05121's Avatar
Mine was $150 from CarQuest
Old Feb 23, 2011 | 06:27 PM
Roadie's Avatar
Check the freon pressure. My 02 AC compressor makes a little noise and has since I bought it 30k miles ago. The noise got a little worse when it needed a can of freon which I added about a year ago. I can hear the noise better inside the truck than I can listening under the hood. So far it continues to work just fine! Knock on wood!
Old Feb 23, 2011 | 08:49 PM
jbrew's Avatar
Originally Posted by paker
Thanks for the tip.
No problem. What goes on I've noticed, a certain seller will get about 2 Crown Vic crate engines per year. He sells everything off of them except for the block and heads for some reason. Long blocks, so you have to keep an eye on ebay.
I've purchased coils, engine harness and injectors from the guy and asked that he get a hold of me when has them. He hasn't yet and probably won't so keep an eye out.
Old Feb 23, 2011 | 09:34 PM
you could just be low on refrigerant, get it checked out professionally so you dont overfill the system
Old Feb 24, 2011 | 08:10 AM
projectSHO89's Avatar
Check the hub! The plate separates and the front end wobbles around and causes the rattling, especially when the clutch isn't engaged. Eventually, the plate will fail to the point it cannot engage the compressor leading to a "no a/c" complaint.
Replace the hub ONLY with the correct Motorcraft replacement part. Around $40-50 from sponsor RockAuto.
Old Feb 24, 2011 | 09:05 AM
larbec's Avatar
Can someone provide a drawing or tell me how to get access to my compressor. Do I crawl on my back and look underneath the truck. I am a newbie but I think I found it on the passenger side on the bottom.
Old Feb 24, 2011 | 09:12 AM
Red02FX4's Avatar
Next time you find him, save him as a "favorite seller" then you can always check their inventory
Old Feb 24, 2011 | 09:15 AM
jbrew's Avatar
I do -
http://myworld.ebay.com/ebaymotors/r...MEFSX:SELLERID
Yea, he doesn't have much right now lol.
Old Feb 24, 2011 | 09:29 AM
Red02FX4's Avatar
Gotcha. I save him also. Looks like real good prices
Old Feb 24, 2011 | 09:48 AM
jump n's Avatar
I'm getting my a/c compressor and system checked out tomorrow. I've had what sounds like a belt squeal coming from it intermittently lately, and had to recharge my a/c twice last summer, so I'm pretty sure it's on it's way out. Will see what the problem is and post here too. I figure with 136K miles and 12 years old, it's probably done for.
