Fog Light ?
Old Feb 19, 2011 | 04:56 PM
stugraham's Avatar
you need the controllerout of that expy mine was the same u need the controller inside that has the indicator
Old Feb 19, 2011 | 08:00 PM
hunterjh's Avatar
Thanx...is this all ima need?
Old Feb 19, 2011 | 08:09 PM
79rocket's Avatar
My last 2 vehicles i put stock fogs into, i wired them standalone with their own switch, so that i could have them on with the brights. I live out of town and do alot of highway driving, just a thought.
Old Feb 19, 2011 | 08:36 PM
hunterjh's Avatar
Yeah ima do that if this switch thing doesnt work
Old Feb 19, 2011 | 10:21 PM
dirtyd88's Avatar
You don't necessarily have to get an OEM switch. I myself have the fog lights wired up separately, which allows me to use them any time I desire, whether headlights are on or not.
And if I'm not mistaken, the 97/98 trucks still utilized 9145 bulbs for the fog lights, correct?
Old Feb 19, 2011 | 10:23 PM
hunterjh's Avatar
This is a 9006 bulb
Old Feb 19, 2011 | 10:29 PM
dirtyd88's Avatar
Okay. You are probably right. I couldn't remember if the 97-98 truck had the same bulbs or not.
Old Feb 19, 2011 | 10:33 PM
hunterjh's Avatar
Yeah i know the 03's are different thats for sure...my gf has one and hers would not work haha
Old Feb 19, 2011 | 11:04 PM
dirtyd88's Avatar
have you checked the prices from Tasca Ford Parts? They sell all their stuff for 10% over cost, so you may be able to get a break on the cost of the light switch.
Find one at a junkyard is very hit and miss.
I still think your best bet would be to add a separate, stealth/hidden switch beside your steering wheel that you can use to turn them on whenever you'd like. Just my $0.02.
Old Feb 19, 2011 | 11:43 PM
hunterjh's Avatar
^yeah i might do that ....the switch is like 3 or 4 dollars from my pick yard...i wouldnt mind gettin it for a cleaner look...i already have a switch for lights behind my grill so it would be easy to do
Old Feb 20, 2011 | 01:45 PM
fairlaner's Avatar
The switch for a '97-'99 is different than for a '00-'03 (although they look very similiar in the dash). All '97-'99 switches will pull out (it's part of the switch removal process), but only the switches w/ the fog indicator are wired for fogs. If you get a new switch, it must be from a '97-'99 to work in your '97.
If you decide to go to a seperate harness for your fog lights, here's how I wired some grill lights to a factory fog light switch (you would run the wires to your fog lights instead of grill lights) ... Installed lights behind grill
Old Feb 20, 2011 | 02:22 PM
Raptor05121's Avatar
Derek, 97-98 had 9006 bulbs, while 99-03 F-150s had 9145.
Thanks for the info fairlaner, I was wondering that as well, I think i've seen three different light switches at a junkyard so I was getting confused myself
Old Feb 20, 2011 | 04:27 PM
dirtyd88's Avatar
okay.
Maybe what I remember was that you could use 9005 in both, since a 9006 is just a higher watt 9005...that may be it.
Old Feb 20, 2011 | 11:53 PM
Originally Posted by dirtyd88
okay.
If I had a 97 or 98 fog bumper, I'd jump straight to 9012 HIR w/ clear lens
