Axle Help
Old Jan 20, 2011 | 01:44 PM
1998f150wes's Avatar
Axle Help
What axle do i have is it a 9.75 or a 8.8 my axle code is 19
please help so i can order lockers
Old Jan 20, 2011 | 01:51 PM
Toyz's Avatar
What engine?
10 bolt differential cover is 8.8 (mostly 4.2L and 4.6L), 12 bolts is 9.75 (which was mostly in the 5.4L's)
The gear ratio is 3.55 non limited slip
It will also tell you on your rear axle tag code
Old Jan 20, 2011 | 10:55 PM
Carcrazygts2's Avatar
if you have a 5.4 it will have 9.75. if its a 4.6 or 4.2 it will have a 8.8...
Old Jan 21, 2011 | 04:21 PM
19 — 3.55 non-limited slip — F-150
25 — 4.10 non-limited slip — F-150
26 — 3.73 non-limited slip — F-150/Mark LT
27 — 3.31 non-limited slip — F-150
B5 — 4.10 limited slip — F-150
B6 — 3.73 limited slip — F-150/Mark LT
H9 — 3.55 limited slip — F-150
If you look at the rear end, the pumpkin is symmetrical its the 8.8 if its bigger on the left its the 9.75
