offroad with a manual?
Old Dec 13, 2010 | 06:35 PM
NJF150's Avatar
well, getting a stang, gonna turn the f150 into a SAS trail rig. my question is, does anyone ride offroad with manual tranny?
Old Dec 14, 2010 | 05:21 AM
Real men do.
Old Dec 14, 2010 | 08:09 AM
Bansheeman6100's Avatar
yeah, i've always wanted to take a manual offroad. although i dont think any of the mustangs or the 3500 Cummine dually 2WD would have done very well
im hoping to do a ZF5 swap into this truck eventually
Old Dec 14, 2010 | 09:57 AM
03Fx4JD's Avatar
my 93 4x4 was a manual... use to mud ride in it all the time. Not sure about any technical riding though, if thats what you mean. In that case I'm gonna go with GLC and say yeah, only real men do...
Old Dec 14, 2010 | 10:49 AM
NJF150's Avatar
alrighty, well lemme ask this. can the M5OD handle trail riding? i think its gonna be 38s with 4.56 lockers.
Old Dec 14, 2010 | 11:51 AM
I'm gonna go with no most likely
Old Dec 14, 2010 | 01:38 PM
Raptor05121's Avatar
if you've got the right gears it'll handle it no prob
Old Dec 14, 2010 | 11:27 PM
MuddYMesS's Avatar
trail riding and mudding is best with a manual imo..... you have the option of gears over an automatic, and the fact water/ mud will not eat a manual tranny as it does an automatic. keep a good clutch that is free of mud and keep fresh tranny fluid in the truck and it will be great. With an automatic the slightest water/mud in the tranny will cause slipping and malfuntions. like i said kep the clutch mud free and if you go through deep water change the fluid and you will have an awsome trail riding rig..............
Old Dec 14, 2010 | 11:36 PM
mustangjonny84's Avatar
My '95 Bronco did just fine with it's M5OD. Yes, it was pretty close to stock...and only had 31's...but I think if you pick good lines, you'll get places that others won't.
Old Dec 14, 2010 | 11:39 PM
As long as your low range 4wd works, the M5OD can handle it. It doesn't have a granny gear like a ZF.
Old Dec 15, 2010 | 12:29 PM
str8t six's Avatar
i didnt like offroading with a 5spd. just my personal preference. although it is fun reving and dropping the clutch in some thick mud!!
but i would go with 4.88 gears with those 38's. that will help the transmission better than 4.56's
Old Dec 15, 2010 | 03:24 PM
MuddYMesS's Avatar
with a manual transmision you can use youre clutch to help you get through those sticky situations by using the clutch to "lurch" the truck through that thick mess. just my opinion
Old Dec 16, 2010 | 11:55 AM
fairlaner's Avatar
This is the first 4X4 I've owned w/ an auto trans. Some ways I like it better, some ways I don't. I never see mud (I live in California), mostly puttin' along on dirt roads in the desert.
Old Dec 16, 2010 | 12:17 PM
ChrisT's Avatar
I sure do miss a manual. My first F150 was a manual. It was sometimes a PITA to drive in stop and go but over all fun to drive.
Old Jan 8, 2011 | 04:24 PM
JMC's Avatar
JMC
25 Year Member
If you keep a stock clutch the tranny might hold up. If you get a good clutch that won't slip expect to break something with big tires.
