New Stebel TM-80/2 Electromagnetic Horns
So since my high-pitch horn got crushed in my last wreck, I ordered a set of new Stebel horns. They have the same shape as the old ones (but a bit thicker) and with some extra wiring, I was able to ground them in series. I also found my OEM low-pitch, so I also mounted that. So basically I have a LOW - HIGH - LOW system.
The Stebel brand is a high-quality horn company from Italy. They make electromagnets, electropneumatics, and straight pneumatic horns (tugs/trucks/ambulances). The electropneumatic Nautilus is a great horn (check it out on You Tube) but it required extra wiring and a different mounting spot. I wanted a simple, PnP, OEM-replacement, with a bit better quality. They put out 138dB with a warranted 50,000 cycles.
And the video:
Doesn't sound like much, but its louder in the cab as well as outside. Slightly higher pitch than OEM, but I like it. Not bad for $23 shipped.
And the video:
