How to tell...
Old Nov 15, 2010 | 05:18 PM
SSCULLY's Avatar
Originally Posted by ford4life.
I have this white box.. Key cycle did nothing..
...<snip>....
That looks too low, the cable for the shift indicator is right next to it.
Did it have a large 5 digit number on it ?
Also does not seems to have enough wires from it, and the unit is too small ( it is about the depth of the connector, not ~ 4"x5"
Looking at the picture, it has a REd w/ Black stripe wire and a Light green w/ black stripe wire, both look to be 12 AWG. Quick look those colors are not on the RAP or CSM
Old Nov 15, 2010 | 05:29 PM
ford4life.'s Avatar
it has 5 digits but not all numbers has two letters
Old Nov 15, 2010 | 09:38 PM
SSCULLY's Avatar
That is not the RAP / CSM.
Look at the 2nd picture, you see the parking brake. looking straight up behind the dash from there, you would see the RAP / CSM if installed.
Old Nov 21, 2010 | 10:11 PM
supercrewzn's Avatar
I got a key fob from a crown vic, did the key cycle and now I have keyless entry!! WOOT!!!
Old Nov 22, 2010 | 08:44 PM
Ok, so I picked up a really nice set of navi handles. It has the key pad. That one pic that shows actuator on the box, I assume that is the key pad? I didn't get anything else out of the door except the handle with keypad. This should plug right up and work, correct??
