Painting dash help
Old Nov 7, 2010 | 01:27 PM
gtboy2k's Avatar
Painting dash help
Hey all,
I was thinking about spraying my dash similar to
thejake1989
http://i615.photobucket.com/albums/t...9/DSCF9846.jpg
-or-
1clean42
http://i171.photobucket.com/albums/u...b/100_1271.jpg
And I was just wondering if there have been any write-ups, or if anyone has any general advice. Thanks!
Old Nov 7, 2010 | 06:17 PM
thejake1989's Avatar
you need help getting it out or painting?
painting i just used adhesion promoter and then krylon fusion satin black and its held up for almost a yr now
Old Nov 7, 2010 | 10:50 PM
gtboy2k's Avatar
Painting, looking for a durable, fade resistant black satin (oem type) finish. So to clarify 1) sand? if so what grit do you recommend 2) adhesion promoter (brand?) 3) krylon fusion satin black (how many coats do you recommend?)
I appreciate your help, I have attempted rattle can paint jobs on odds and ends before and it doesn't always come out the greatest, so I am trying to leave no room for error on my dash, because seeing as it's my daily driver, I will have to see it every day.
Old Nov 7, 2010 | 10:55 PM
ford4life.'s Avatar
i have used dupli color inter paint in my mustang.. holds up well.. i did not use promoter but you should.. i have a couple spots pealing..
Old Nov 7, 2010 | 11:49 PM
i used duplicolor adhesion promoter and use some paper that will rough it up some but i didnt go too rough and take off the texture on mine. maybe 600-800 grit will be fine.
then for the color i used about 3 or till it looked good since i used a flat rustoleum first and didnt like it. just make sure its not too humid or cold out and you should be fine.
