Wipers problem and GEM
Old Oct 26, 2010 | 06:11 PM
thejake1989's Avatar
Exclamation Wipers problem and GEM
So here goes again. another messed up wipers and dome light issue.
all the threads ive search through just seem to die before being fully resolved.
my specific problem
no wipers
no dome or map lights
no door chime
i used this thread with posts from sscully
https://www.f150online.com/forums/el...-problems.html
and i jumped the washer pump relay and the interior lamp relay and the dome light worked but no maps or reaction to the door being open or shut.
the washer pump worked with the jumper and the key in the on position.
my problem is idk where to go from here. i found a write up on swapping the GEM but idk if thats what i need to do for sure or where to get one.
any help is welcome im running out of time before it rains again in texas and i cant afford to not have a drivable truck.
Old Oct 26, 2010 | 06:15 PM
to add my turn signals work as well as the high beam selector on the MFS which makes me think its not that
Old Oct 26, 2010 | 06:18 PM
Halverso_99's Avatar
Like I said before jake, i have the same problem but only when its cold/wet out, my wipers will go on and off randomly.
Old Oct 26, 2010 | 06:27 PM
so do they work currently? mine used to do it like that but recently they been off and its been cooler than normal but still warm in the sun
also what about the dome light
Old Oct 26, 2010 | 06:29 PM
Yes they work, and they haven't done it since this spring but i am sure it will start again soon. I haven't had the dome light in the truck in about 3 weeks as the interior and headliner is out but i have never had any problems with it.
Old Oct 28, 2010 | 10:38 AM
decided im gonna pull the GEM and fuse panel this afternoon and see whats up.
gonna probably need/order one of these
Old Oct 28, 2010 | 02:12 PM
GaNole07's Avatar
I had that problem with my old ranger, got a module from pick and pull that fixed it for $5
Old Oct 28, 2010 | 02:19 PM
Klitch's Avatar
:O
Thats a fair amount of work to get the GEM out... There is suppose to be a way to test it as well. which leads to this next part.
Jake: I have read certain years had issues with moisture getting into the cab and dripping onto GEM, it was a known issue for certain years (found info on here one time)
I also assume you've verified fuses are good
Old Oct 28, 2010 | 05:30 PM
yea i checked the fuses and the normally open relays and they all tested good.
i just pulled it out and it wasnt as bad as you would think but damn what a piece of junk the GEM is its so cheap idk how ford could charge 400 for one.
still dont know if its my problem or not
Old Oct 28, 2010 | 07:13 PM
heres some pics of the connectors from the fuse box and the GEM
and the inside of a basic GEM module
Old Oct 28, 2010 | 07:14 PM
GaNole07's Avatar
Mine in my ranger looked like that..the dome light would blink on and off with the door open and the chime sounded weird, then the wipers would work every now and then and finally went out. Check if you have a pick and pull or a decent junk yard nearby no way i'd pay 400 for that pos
Old Oct 28, 2010 | 07:15 PM
yea im on ebay and yards also. cant get one new cuz ford doesnt sell them anymore and your right a 5 yr old could make it haha
Old Oct 29, 2010 | 03:25 AM
Klitch's Avatar
learn me how to remove that STUPID door chime.
Old Oct 29, 2010 | 09:25 AM
The way I did it was to let water leak down and short out the GEM works pretty well in my truck hahha
Old Oct 29, 2010 | 08:55 PM
Well put it all back together so I could drive the truck and it's still doing the same thing so I know I didn't break it any more but I'm still pissed
