Bigger upper control arms
sorry they are so big, they actually came off my iphone. These are not on my truck but are very similar to what I want to make, however I want to use a slightly smaller angle to keep the arms a little narrower where they are close to the rim, apparently on one of the trucks they rub the wheel because it has the wrong offset I guess
no they are not long travel, eventually that is my goal but for now I figure I think I can build these for a few hundred dollars and its about time to replace my originals anyway. Would basically allow you to run a slightly larger coil spacer and still adjust for the camber with the heims instead of messing around with alignment cams and stuff. Also a uniball would be much stronger, to the point where you are going to break the bolt (will def run grade 8 or better) or possibly the spindle even.
Yeah I have 12" wide wheels and I wouldn't want them rubbing. I'm definitely interested as well if you can come up with something that will work. If your really serious about making them, please let me know.
I think Im gonna build myself a set first and figure out what it actually costs and then if they turn out good I might be able to make a few more sets...will be prob a month or two before I actually tackle though, but Ill def let ya know!
yeah my current balljoint and control arm setup should last until jan. Hopefully you can figure something out by then. I'm just ready for 3 more inches of suspension lift and a 3" body lift. 10" lift on my 2wd should be pretty nice! lol
Ordered the new uppers today. Gonna be going for that cali look for a little while with a lot of lift and not as big tires. Oh well should look sick with the rake in the front and an extra 2 inches.
The link that Jake put on here. I guess they are Springtech or Canuck Motorsports from what it says. I'm interested to see if it will be Doetsch though. Either way I know both have good quality products. I'll put some pics up when I receive them.
