Changing from 5x135 to 6x135
Old Oct 7, 2010 | 01:21 AM
  #31
4.2trimble's Avatar
Originally Posted by Halverso_99
main reason why i want to do this!!!
If you really want to convert your torsion based suspension over to a NBS coilover suspension id just look into a long travel kit, There are some good ones out there. And its not something that you are piecing together.
IMO it would be much easier to SAS a truck than do what you are talking. But you would have to lift it at least 7-9" Look at Klitch's setup and if you like that then go that route. He can clear 37's. Basically looks like a F250 suspension (leaf springs)
Old Oct 7, 2010 | 10:09 AM
  #32
Halverso_99's Avatar
So what parts would i need to do an SAS?
Old Oct 7, 2010 | 10:14 AM
  #33
thejake1989's Avatar
look up klitch's thread
Old Oct 7, 2010 | 02:35 PM
  #34
4.2trimble's Avatar
Front and rear axles, leaf springs, front crossmember, shackles, steering. (Farmboy Fabrications Kit will emilinate them)
Old Oct 7, 2010 | 08:42 PM
  #35
Lightning Expo's Avatar
Trimble, how much for the SAS conversion such as Klitches? Same concept on a 2wd?
Old Oct 7, 2010 | 08:49 PM
  #36
offroadn'98's Avatar
ALOT cheaper..lol
Old Oct 7, 2010 | 10:51 PM
  #37
4.2trimble's Avatar
Alot depends on what kinda deals you buy but on the low end id say 4k minimum to get the truck rolling again.
Add around 250-300 for a divorced NP205 then another 300-500 to get it mounted and all the fabrication to get it hanging.
I say you could do a SAS 2wd to 4wd for 6-7k if you stay in the same hiegth range as klitch. Then you will have to think about gearing and building the axles.
These prices are if you do the work yourself.
