Radiator Questions
Radiator Questions
I know this is probably an easy task, and I can probably do it without asking how after enough effort BUT just incase I would like to know what im doing so I dont screw it up. Ordered new radiator for my truck, how do i remove and re-install? PLUS I have an electric fan, and it looks difficult to remove and re-install also.
remove the upper return line. use a pair of pliars to grab the metal clamp and slide it off. then do the same for the lower feed line. also do this for the small feed line up top going to the degas bottle. then use (IIRC 8mm) and remove the two metal bushings on the radiator support and lift right out.
