4-wheel drive not engaging
Old Sep 16, 2010 | 01:06 PM
iam4uf's Avatar
Hi, I have a 1998 Ford F150 that will not lock into 4-wheel drive. The light on the dash comes on and that's it. Anyone have the same problem? Thanks
Old Sep 16, 2010 | 03:04 PM
mcolford's Avatar
Check the fluid level in the t-case.
Old Sep 17, 2010 | 09:03 AM
iam4uf's Avatar
Checked that first thing and it was fine.
Old Sep 17, 2010 | 12:12 PM
Cetansapa's Avatar
With mine the vaccuum actuator went bad. It is somewhere to start at least.
Old Sep 17, 2010 | 12:20 PM
iam4uf's Avatar
Where is that located? Is it hard to replace?
Old Sep 17, 2010 | 04:41 PM
Cetansapa's Avatar
Since I have to take everything to the shop. I have nowhere to work on it. I really cant say. I am sure that someone here does know.
Old Oct 1, 2010 | 12:04 AM
thesnowman269's Avatar
located on your front axle, not teribly hard to replace with simple mechanical skills, when looking at the front axle its located behind the plastic cover and held in place by a c clip. I would recomend moving the lever the vaccum is attached to all the way to the left with a peice of string putting the truck in 4wd and seeing if it works. if it does then its the vaccum. if it doesnt.. take it to a mechanic its a bitch to fix and be ready for a hefty repair bill the part alone costs over $200, its the fork in the axle tube it was a bitch to replace...
