Console Build
spent most of the afternoon finishing up the prep
heres it ready for paint
in primer
Heres the two spots i have to fix later after the primer dries
in primer
me either. still got a little ways to go. need to do some more prep and then finish sanding and more primer and then paint. i shot it with black and the sanding lines are showing so i need to fix that also
What are you sanding with? I would be using like a max 400 on primer.
the glazing putty was sanded with p80 and then a light run with some 320 before the primer and then the primer wasnt sanded before the black went on but im gonna strip most of the black off and add more glazing putty and sand some areas and then work from the 80 to 320 to 600 (maybe 1000) before primer and then then primer will be wetsand
jeff... i have no words
600 would be the most I did before the primer. The primer will fill all of the scratches that your eye can see so you would just be doing more work. After the primer you could start at 600 then go to 1000 if you want but the 600 would be good then too. 600 was the finest I ever used on anything before paint and the body shop and it always turned out good.
Good one Jeff!
