Fog Light Wiring.....
Old Sep 12, 2010 | 06:55 PM
mustang8998's Avatar
I've searched everywhere and can't find an answer. I'm trying to wire my fog lights, so that they come on with the parking lights.
I've seen the "how to" for the 2000 and up, but I have a '99 and the harness is different.
I've already altered the ramp, so the switch pulls out, in the parking light position.
I need to know what wires to splice.
Thanks!
Old Sep 12, 2010 | 07:59 PM
Powers150's Avatar
splice the brown wire into the white wire with the black stripe and youll be all set i did this on my truck and it worked great .. good luck
Old Sep 12, 2010 | 08:02 PM
Again, yours is an '01, different wiring harness. I don't doubt your reply, just not sure if the wire colors are the same.
Thanks for the reply!
Old Sep 13, 2010 | 12:16 PM
Bluegrass's Avatar
Here is a different take on what you want to do.
Fog lights will be an extra load on the park light circuit such that the fuse may need to be larger.
If there should be a failure of the fuse, all the lamps are out.
It would be a good idea to install a seperate relay that operates from the parking circuit as a very low extra load.
Then with a new fused 12 v source, feed the relay then to the Fog lamps independently.
You can even put a switch in the relay lead to have the option of using the Fogs or not.
This is really a very simple mod to wire up.
Good luck.
Old Sep 14, 2010 | 10:15 PM
fairlaner's Avatar
I believe this is also correct for a '99 ... at least that's what worked on my '99, as described here (see line of text after the first picture). Although I was wiring aftermarket lights to a factory fog switch, the mod to the switch wiring should be the same as using the factory fog lights.
Old Sep 15, 2010 | 05:35 PM
Powers150's Avatar
i got that from a 99 write up and thought mine would be different but i was told it would work so it is the same color wires also i didnt need any bigger fuse or anything and havent had any problems and its been about a year
Old Sep 15, 2010 | 09:04 PM
Thanks for the link!
Looks like the wiring is the same, just different plugs.
I'll give it a try, this weekend.
Old Sep 20, 2010 | 04:32 PM
That did it!
Thank you, to all that replied!
