Auxiliary Back-Up lights?? Help.
This is what i used
Grote grommet part # 91740 (you can use what ever brand you want for this its all the same) should be available at any tractor supply store.
A pair of round fog lights that i bought at Canadian Tire. Don't have a link they are just some 3.5" fogs that i got from there, should be able to find something at like walmart, or advance auto or the sort.
A relay, some wiring, a switch. I have mine wired up so i can turn it on at anytime, you can wire it up to your reverse, but I hook up trailers at night so i use them for that alot.
Oh and a 4.5" hole saw to cut the holes for the grommets.
at first with some zip ties , then i made some brackets. where i put them is right in between the to bumper bracket plates.
