2002 Ford F150 5.4L V8
do you have the manual or electronic controlled A/C system? I have the electronic system and the same thing happened a while back. Thought it was the usual suspect vacuum leak but turned out I needed a whole new A/C control system. Not cheap!
can you elaborate on the not cheap part? i was worried about that when i was looking at them.
A brand new one from the dealer I think is around $600? I ended up getting a used one from from a junk yard that I talked him down to $100 with a guarantee that it was in perfect working order, and luckily it was. If I had the option I would have the normal manual A/C controls instead!
