1997 F150 4+4 fuel milage probl.
Old Jun 14, 2010 | 09:07 AM
FX41's Avatar
Originally Posted by jtfflying
you no you can stick it!!!!!
i was looking for help not a smart ***!!! and the truck was like this when i bought it dip****!!
Take is easy there 8 posts.....
Terajerame is right. There are guys on this site that have larger tires and bigger lifts and getting better gas mileage than you because they do the appropriate research and do the work. Attitudes like this wont get you very far here. Tera and others like him are wealths of knowledge when it comes to these trucks, but if you refuse to see the obvious they probably can't help you.
Old Jun 14, 2010 | 09:59 PM
jtfflying's Avatar
sorry for getting mad thats why im here to get help!!! i took it he was maken fun of me!!! spelling is not the best but i try! im here for all the help i can get guy's.. i have never had this problem before big truck and all lol i like it and would like to get the best millage i can get out of it.. yall sed see what gears i have i looked on sticker and im not sure what im looking for!! i seen a spot that sed axel-19 but i dont thank thats what yall are talking about!! guys i appreciate all yalls help!!! SORRY Terajerame i gues i took you wrong.
Old Jun 14, 2010 | 10:31 PM
03fx4driver's Avatar
its the 4wd and gearing i guess that kills the mileage. my 03 fx4 5.4 with 37's and 4.56 gears gets about 12.5 less than 100k miles. my 01 2wd 4.6 w/140k miles has 37s also with 4.10 gears and it gets 14.5 in town. used to have a 97 4.6 4wd also that got about 11.5----so it is what it is...
Old Jun 14, 2010 | 10:41 PM
i just realized something...in 97 those trucks came from the factory with a small tire size of like 235/70R16's or 245/75R16's which is quite a bit smaller than 33". the gears are most likely 3.55's, if you call the dealer they should be able to tell you how to locate your axle code, tell them the code and they can tell you the gear ratio. if its 3.55's now, i would recommend 3.73's or the next gear lower (if you want to spend the money replacing gears and i would do both sets if you ever plan to use 4wd again)
Old Jun 15, 2010 | 08:20 AM
Veteran: Army
he could also go look on his door tag and post the axle code here...
Old Jun 15, 2010 | 01:43 PM
jtfflying's Avatar
hey sorry gues i got two post going lol i lookt and it says axle# 19 thanks for your help!
Old Jun 15, 2010 | 02:30 PM
Axle 19 is 3.55 non limited slip.
Like I said - my son in law has a 98 supercab 4x4 with offroad package - 4.6 and 3.55's - and he averages about 13. With your lift and bigger tires, 11 sounds about right.
Old Jun 15, 2010 | 04:26 PM
Cetansapa's Avatar
I have a 97 4X4 with the 4.6 and oversize tires. Bought it that way. No Lift yet. I still get 12 MPG.
Old Jun 15, 2010 | 07:26 PM
FX41's Avatar
You can get better mileage if you re-gear. The 4x4 stuff really weighs it down though. Best things you can do to get better mpgs are re-gear and custom tuning.
Old Dec 2, 2011 | 10:23 AM
1997 lariat 4.6's Avatar
my 1997 has the 4.6. with about 158,000 on original motor and tranny. i broke the EGR line off the exhaust manifold and my mpg's dropped to about 5... I had to replace the line and fitting, but its back to around 10 to 11 where it has always been it has stock lift, "for now." My dad had bought his first new f150 in 1997 as well, it got around 10 when he bought it up until he sold it at about 25,000 miles.
