Just saying hello
Old May 15, 2010 | 11:25 AM
HighLife's Avatar
Just saying hello
So guys I've checked this site out a few times over the years and finally decided to register so I could chime in on some of the topics.
Heres my truck, 2002 Screw 4x4. 6" Fabtech suspension lift, 3" body lift, this poor truck sees more airtime than the General Lee and it gives me practically no problems (except the plastic intake manifold that just cracked and started leaking coolant)
Old May 15, 2010 | 11:28 AM
Welcome to the site! Very nice truck, too
Old May 15, 2010 | 01:04 PM
Veteran: Army
welcome, what gears are you running??
Old May 15, 2010 | 02:11 PM
HighLife's Avatar
3.73 rear end gears because those 36's and 20" wheels are super light compared to most. Has great pick up from a stop and still can cruise the highways at whatever speed I want at relatively low RPM.
Old May 15, 2010 | 03:39 PM
Red02FX4's Avatar
Nice ride And welcome to the forums. Got any videos of that 'air time'?
Old May 15, 2010 | 03:54 PM
Cetansapa's Avatar
Welcome!!!!!!!!!
Nice Truck.........
Old May 15, 2010 | 04:08 PM
dirtyd88's Avatar
That's a sick looking Screw man!!!
You should switch your headlights to some black Lightning style heads, and get some Depo clear fog lights.
Old May 15, 2010 | 04:46 PM
HighLife's Avatar
actually i was trying to decide on new headlights and fogs, the tinted lights were kindof a quick fix because it definately looked better than stock however, the Florida Highway Patrol seems to not like them. I moved my headlight bulbs down into my fog lights after I tinted them and it helped out a lot but it could still be brighter.
Old May 15, 2010 | 04:50 PM
HighLife's Avatar
not yet. Its always in the woods after dark, but one of these days I'll definately get some vids. I just put new everything up under the front end so now I can start bashing it some more without worrying if I can make it home or not.
Old May 15, 2010 | 05:12 PM
Toyz's Avatar
Hunt down a PI intake manifold from a 99, they are the only year I believe that were aluminum I think it is, or some kind of cast metal. Some new gaskets and a good cleaning (throttle body, egr ports and IAC) while its off. Be a whole new truck. Better get to it soon before that crack turns ugly.
Old May 15, 2010 | 05:17 PM
OGTerror's Avatar
That is a nice body style, perfect for a Baja Pre Runner. Welcome to the forum
Old May 15, 2010 | 05:21 PM
HighLife's Avatar
Man, I wish I would have checked here first. I went ahead and tore it apart the other day to see if it was just the small o-ring gasket in the coolant crossover tube (but knowing that I dont have that kind of luck) Once I found the damage I asked around because I knew that I had heard of an aluminum one that would fit but no one knew exactly which one, so i just went ahead and ordered the plastic Dorman manifold for now. But thanks man, Ill keep that in mind and keep my eye out for a used one around to P&P since you cant do that with the plastic ones.
Old May 15, 2010 | 05:59 PM
4x4wolf's Avatar
Good looking truck and welcome to the site
Old May 15, 2010 | 08:23 PM
Dinggus's Avatar
Truck looks sick! You have any pictures of the inside as well?
Old May 15, 2010 | 09:09 PM
Raptor05121's Avatar
You put 9007 bulbs in a H10 socket?
