need help a lifted 97 f150 2wd
Old Apr 30, 2010 | 12:44 AM
  #46
rfgeorge1987's Avatar
ok got my truck done. had to do a little modification but it worked and i got my 38 inch mt baja mtz on
tell me what ya think?
Old Apr 30, 2010 | 12:59 AM
  #47
thejake1989's Avatar
what mod did you have to do and any suspension pics.
Old Apr 30, 2010 | 01:00 AM
  #48
Lightning Expo's Avatar
Wow thats is stuffed but it looks really good. What size spacer did you end up going with? Need more pics of your angles I wanna see that thing underneath and at full lock to see how much rub you got. More pics!!
Old Apr 30, 2010 | 01:05 AM
  #49
b2therad's Avatar
Dude!! NICE
Old Apr 30, 2010 | 10:13 AM
  #50
yea ill get some pics today but it actually didnt ride that bad besides the fact i do have to balance my tires.i have to do some mods to the inside fender. moved the black plastic piece back some.
Old May 1, 2010 | 12:36 PM
  #51
jlstang351's Avatar
The wheels suck @ss but the 38's look pretty good on there.
Old May 1, 2010 | 08:28 PM
  #52
texanfan392's Avatar
balancing wont do a whole lot with those huge tires, but they do look good...the tires. those wheels look stupid
Old May 2, 2010 | 01:50 AM
  #53
doug435's Avatar
dumbest post i have ever read ... you sir are a f'n moron
Old May 5, 2010 | 11:28 AM
  #54
ok i was told that a 302 will bolt straight up to the transmission. is that true?
Old May 5, 2010 | 12:01 PM
  #55
ChrisT's Avatar
To the OP, truck turned out great! Looks really sweet with those tires.
Wow, Doug. Great post there! You might want to educate yourself a bit more before you come on here slamming other members posts and calling them an "f'n moron". In most cases balancing 38" tires is damn near impossible.
Here's a few threads about what people have done in attempt to fix the "bounce" from such large\over sized tires.
http://forums.off-road.com/jeep-shor...big-tires.html
https://www.f150online.com/forums/wh...balancing.html
Old May 5, 2010 | 12:18 PM
  #56
doug435's Avatar
sir if your tire shop can not balance 38's then you need to find a new shop ... **** i have seen 44 balanced that truck i road in and it road as smooth as galss for a truck with 44's. i have even seen a set of 46's that where balanced
but in all reality why not just pop the bead and throw about 2000-2500 20G air soft bb's in each tire ... they work great ... that all is this company sells but just go to wal-mart and use air soft bb's their the same thing at like a 1/4 the cost http://www.innovativebalancing.com/
Old May 5, 2010 | 04:10 PM
  #57
4.2trimble's Avatar
Originally Posted by rfgeorge1987
yea ive always heard shackles were crappy. i have a 3 inch block in the rear. is it safe to stack them? i have a another 2 inch block out in the shed
shackles are fine, but unless you are doing a shackle flip then you arent gonna gain much lift from them. You will also need a set of traction bars because shackle flips allow for more axle wrap
ive just always heard they will break. and jus mess up.
if they are made of cardboard
im still waitin on my pitman arm to get in. im going to try the 1 inch coil spacer and see what that does. i had a talk with my mechanic today and he said yea they would fit that i could possible go with a 2 inch. adding a 2 inch will give me 11 in the front 9 inch in the back so that should be plenty
WTH do you need a drop pitman arm for? You are running IFS you have an idler arm to the right of it that would have to be dropped aswell. I know of a drop pitman arm that will work but its for SAS applications NOT IFS bs pieced together applications
ok another question. the pitman arm i got was not the right one. any interchangeables. or any website?
yes, but you dont need one
do you have a manual or auto?
Have you personally had 40's 44's or 46's balanced... mmm doesnt sound like it. have you personally seen 40,44,or 46's on a machine that said they were balanced? probably not. Heres the difference between me and you, ive ran 40's 44's 46's and 49's and i can tell you theres no way to PERFECTLY balance tires of this size. Sometimes its better just to leave them alone and deal with the extra vibration, the balancing beads work but only when you are going over 20mph slower than that and they REALLY REALLY suck. dyna balancing beads can be put in though the valve stem, but they also have problems letting air leak out the valve stem.
Now 38's on the other hand should be easy to balance, go to a big rig show they can balance them. Specially with such a low profile tire as yours is.
and BTW the setup looks scary as hell, just saying
Old May 5, 2010 | 05:14 PM
  #58
alex7191's Avatar
^ he said hes got a manual
Old May 6, 2010 | 08:00 AM
  #59
hey what is the best gears to go with for 38's?
Old May 6, 2010 | 09:14 AM
  #60
ChrisT's Avatar
I'd go with 4.88 for your 8.8 rear. I think that's lowest you can go with the 8.8, maybe a 5.14?, but I think 4.88 would be best since I believe you said this is also your DD? (not that it matters at this point since you're running 38's )
