need help a lifted 97 f150 2wd
ok i have a 97 f150 2wd with 3 inch lift coils, 3.5 lift spindles, and 3 inch body lift. i have installed new upper controls too. im running 35's on it now. but im wondering if i could add a 2 or 3 inch coil spacer to what i have now.im trying to lift it up high enough so that i could run 38's. any help??
No dont think so. Longer upper control arms might make it alignable how it is but it doesnt put anymore room between the coil bucket on the frame and the lower arm. Really all i think it would do is compress your 3 inch coils and make your ride even worse. If you could even bolt it back together!
That would be a pretty insane setup. That thing would ride stiff as a board and like alex said I don't think you could bolt it back together. If you wanna go bigger your gonna need a new drop down crossmember. I'd like to see those pictures because I have no idea how you got that thing aligned because I'm running a 2" spacer and my camber/caster is almost maxed out.
I'm not really sure what else you can do with what you have. They use to make 6" spindles but I don't think they make them anymore. Your alignment has to be maxed out so you can't go with bigger springs. I think you need to look into a Fabtech lift kit or others. Theres one on ebay right now for 650 and its almost new. Someone else might know something I don't but I'm pretty sure your gonna need a new crossmember to go bigger. Something that lowers the lower control arms to gain more lift. Your truck looks great though, I really like the rims.
when i had the spindles put on i had new upper control arms with lower ball joints put on. i took to a place called columbus springs and they installed a camber kit to get it aligned. im goin to attempt a 1 inch spring spacer.ive already ordered a drop pitman arm jus waiting for it to get in
Your gonna spend more on custom spindles than you would on a lift kit and it wouldn't be as safe. A big *** spindle just seems dangerous to me. B2, you think that kit is a scam? Before I purchased mine I was talking to him for awhile and we almost came to a deal, he seemed legit.
