my center console swap
Old Apr 30, 2010 | 02:02 AM
  #31
jdlowesracer's Avatar
I have a narrow top console in mine but did that because I already had the bucket seats. I have heard of some guys taking the armrests off too and using a widetop. Either way I love it and wished Ford had done this to begin with, just looks so much better.
Old Apr 30, 2010 | 02:24 AM
  #32
BigTruckGuy's Avatar
Originally Posted by jump n
OK, had to tinker a few more things here. I decided to mount 12 volt power points for my kids' games, place for portable dvd player, etc...
I decided to use the original rear stereo control frame as a template, along with the opening of the rear of the console. I cut out unecessary plastic from the plate.
I marked where I wanted to drill holes for the power point housings. I should have used a 1 -1/8" spade bit. I used a 1" spade bit, and had to do some reaming to get the housings in. Then I wrapped the vinyl around after some sanding to smooth the edges. It fits very tight in the mounting tabs, and the power points fit really tight with the extra material from the vinyl assisting to hold them in place. I'm happy with how they turned out.
The holes may be slightly asymmetric, but it's close enough for me!!
what is giving these power? what did you tap them into??
Old Apr 30, 2010 | 04:21 AM
  #33
willys5555's Avatar
I put the wide top in mine and took my arm rests off. If you dont have seat covers, i think it might look a little funny cause there is holes in the sides of the seats but the covers i have, have velcro sides that i just closed up when i took off the arm rests. mine has custom fiberglassed guages in the front part of the console where there would jsut be a hole in these. I really like mine, and i really like the idea of putting power points in the rear of it. good looking swap man.
Old Apr 30, 2010 | 10:06 AM
  #34
05_sprcrw's Avatar
Looks awesome great work Jump_n can't wait to see it in person.
Old Apr 30, 2010 | 10:33 PM
  #35
jump n's Avatar
I have 8 gauge amp wire running back under my seat. I'm going to tap into that for the power.
Old May 1, 2010 | 07:15 PM
  #36
gotcha
