Sputtering issue?
Old Mar 4, 2010 | 08:37 PM
lost cause's Avatar
Sputtering issue?
I have a 2002 f150 with the 5.4 and it just recently started sputtering like it is missing on one of the cylinders. the spark plugs are not that old and there is no check engine light or code. I am thinking it is one of the coils but how do i figure out which one. I did recently spray out under the hood but i just used a garden hose briefly. could a coil get messed up that easily?
Old Mar 4, 2010 | 09:10 PM
jbrew's Avatar
Yea, that's not a very good thing to do,- to your motor I'm afraid. Your not alone, many have done the same thing. Only one thing you can do that's cost effective. Blow out the plug chambers and hand dry everything, - your coils, connectors and wiring.
Put it back together and if the miss is still present, jump on ebay and purchase a set of 8 new coils. Sets go for about $76 + shipping.
And don't do that again lol.
Good Luck.
Old Mar 4, 2010 | 09:13 PM
Tumba's Avatar
yes they can. The spark plug wells are water traps. You might try blowing the holes out with compressed air. You might get lucky enough, that it may fix it.
Old Mar 4, 2010 | 10:34 PM
lost cause's Avatar
awesome. thanks guys. hopefully i can just get them to dry out and i guess i wont be washing under the hood anymore.
Old Mar 4, 2010 | 11:22 PM
jbrew's Avatar
Hopefully, I think you have a 50/50 chance, if that. Usually that kind of trauma causes your windings to shear. If you shear one to many wires, you get a low grade misfire.
If you need new ones, get them here @ Global. These are OEM's.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
