Climate control problems
Old Jan 29, 2010 | 02:12 AM
rednutbow's Avatar
I have the climate control where you just set the temp. The problem im having is it will not go to floor! If i press floor it just goes to defrost. I know my system is vacuum operated, my guess it has a leak somewhere... that just seems like a pain tearing the dash apart. Has anyone else had this problem? if so how did you fix it?
Thanks David
Old Jan 29, 2010 | 07:20 AM
torkum's Avatar
Check the vacuum fitting that goes into the firewall behind the battery. Its a common break point.
Old Jan 29, 2010 | 07:32 AM
Tumba's Avatar
I'm not suggesting this is your problem, but this link is a very interesting one
to do with climate control problems. When you rule out vacuum leaks, you might look into this
https://www.f150online.com/forums/hv...buildable.html
Old Jan 29, 2010 | 10:55 AM
rednutbow's Avatar
well I would think if I have a vacuum leak that non of it would work... right? it will switch between everything else but floor. Im going to look at that link now.
Ok when I get to my truck today, ill check the one behind the battery, and if thats good im tearing out the EATC.
Old Feb 1, 2010 | 02:04 PM
rednutbow's Avatar
tumba THANKS very much, that fixed it!
Old Feb 1, 2010 | 02:08 PM
Jesso's Avatar
Good deal!!! I'm always glad when somebody can come on here and fix their problems without paying out the @$$ for a mechanic!!
Old Feb 1, 2010 | 02:31 PM
Tumba's Avatar
Your welcome!
But all I did was save the link. The other guy did all the work.
Old Feb 1, 2010 | 04:29 PM
rednutbow's Avatar
well I searched but I didnt find it... but yeah thank ALOT to the guy who posted the how to
