Rust Problems??
Old Jan 27, 2010 | 02:27 AM
BigTruckGuy's Avatar
Rust Problems??
Does anyone else have rust problems like i do? I have rust all on my underbody of my truck.
Does anyone know how to get rid of rust? Can you?
Old Jan 27, 2010 | 02:28 AM
TIDOSFX4's Avatar
If it has not started to eat its way into the metal and is just surface rust you can sandblast or simply sand it off, then I would use a rubberized undercoating.
Old Jan 27, 2010 | 02:34 AM
Ok. Thanks
And what if it has ate into the metal?
Old Jan 27, 2010 | 02:36 AM
TIDOSFX4's Avatar
Its still the same process but now you just have to fix it with welding.
Old Jan 27, 2010 | 10:39 AM
fordracing200's Avatar
My DS door is starting to chip at the bottom, the pass rear is blistering and my rockers have some rust...........I hate salt....I wash it religisouly, its just I bought it used....can only do so much.
Old Jan 27, 2010 | 01:51 PM
Alex_4.2L's Avatar
I had some random rust dots on the paint about two years ago but I rubbed them out with compound and waxed the whole truck good and haven't seen them since. As far as underbody I don't knowmaybe I should check. lol
Old Jan 27, 2010 | 06:00 PM
http://www.por15.com/POR-15/productinfo/1GB/
Old Jan 27, 2010 | 06:51 PM
ya none of my truck is rusting thankfully, except for the underbody. Its really bad.
i think il just sand it out and hopefully thatl do the trick.
Old Jan 27, 2010 | 07:05 PM
FordGuy24's Avatar
when you say "underbody" do you mean the literal body or something like the frame?
Old Jan 27, 2010 | 07:13 PM
like EVERYTHING under. Like frame, tow hitch everything on the under side of the truck is rusting. even my exhaust.
If it wasnt dark out id go take pics but to late. maybe tmrw
Old Jan 27, 2010 | 07:15 PM
Well then sand it down and you can easily coat it. I coated my frame with flat back Engine paint. That stuff is tough, looks great still. I have to fine tune the rest of it this summer and do some dressing up. The exhaust... well that's just an excuse to get a custom set-up
Old Jan 27, 2010 | 07:17 PM
how much is that paint a can? where you get it?
Ya this summer is when alot of my Mods will come.
Old Jan 27, 2010 | 07:20 PM
It's only a couple of bucks. The reason I did engine paint, is because it is hi temp, so there is no way that anything is going to be able to get through it. I didn't want rust. The Por-15 stuff is a very good product from the reviews that I have read, however to me, until the day where I can get the cab and bed lifted off the chassis to do some serious painting and protection, I am perfectly fine with my method and saving some serious $$. I feel that it is more durable than the rustoleum regular spray. I believe the engine paint I got was made my rustoleum.
Old Jan 27, 2010 | 07:23 PM
Kingfish02's Avatar
I have the same issues and have never really noticed until today when I pulled the vallance back under the front radiator. The frame that holds the bottom of the cooler was rusted through and dropped about a 1/2 inch allowing the cooler lines to rub and create a leak. What a mess I've got on my hands.
Old Jan 27, 2010 | 07:25 PM
Ok cool. ya im with ya until i lift it its just guna be a pita to try and put that stuff on under there.
