Will not start after core Install
Old Dec 22, 2009 | 11:56 PM
rlowhorn's Avatar
Just completed heater core reinstall. Thought everything went pretty good until I tried to start the truck. Reconnected the battery, and got nothing. No light under hood, no lights in the cab. Electrically dead. Any thoughts? Is there a typical thing that people do during a heater core job that would result in this? I charged up the battery to full charge, and when I tried to connect the cables, positive first, and when I touched the negative terminal it fired off like I was crossing terminals directly?
Old Dec 23, 2009 | 12:56 AM
Raptor05121's Avatar
your shorting something somewhere. try posting in the electrical forum
Old Dec 23, 2009 | 01:48 AM
lil_bizzy's Avatar
Had a start issue in mine, but lights and such worked fine. Starter wire came out of the crimper, put a new one on and reconnected the wires, it's all working fine now. Hope you get it working.
- B
Old Dec 23, 2009 | 12:08 PM
shifty_85's Avatar
you may have taken out a body to frame ground strap i know there is one in that area. if not you deff have somthin shorted. get a volt meter read your batt. then hook the cables up and read again.
