Headlight flash when locking...
Old Dec 10, 2009 | 02:09 PM
scheetz31's Avatar
...i have an 02 screw and have HIDs on the way. The only concern i have is the flash from the headlights when i lock it. anyone know how to reprogram this. i know on the 04+ its a matter of turning the key a number of times but im not sure if its the same for 97-03s. Look in the owners manual and do not see anything.
any suggestions?
Old Dec 10, 2009 | 02:39 PM
Veteran: Army
and you didn't think of that before your ordered your HID's?????
typical
anyway use the search feature
Old Dec 10, 2009 | 03:26 PM
01f1502wd's Avatar
OP if you find it, either send me a PM or post it here where they say how do turn off the flash. Im too lazy to look it up.
Old Dec 10, 2009 | 04:19 PM
ChrisT's Avatar
typical
I was bored\curious so I searched, and I didn't find an definitive resolution to this. I don't think this is a question that is brought up often, so perhaps you're willing to share the knowledge?
To the OP, I think on my 02' F-150, if I only hit the lock button once, it will lock both doors and not flash the head lights. Maybe give that a try in the mean time?
Old Dec 10, 2009 | 05:14 PM
dirtyd88's Avatar
Your HIDs will be fine. I occasionally lock my doors manually, even though I have a Clifford alarm installed, and the HIDs will just flash like normal, and have still worked since.
Just look for a wiring diagram and cut that wire.
Old Dec 10, 2009 | 05:19 PM
alex7191's Avatar
does the headlight flash and horn chirp have a purpose other than to let you know that its locked?
Old Dec 10, 2009 | 07:01 PM
JNC995's Avatar
What's wrong with having HIDs, and allowing the headlights to flash???
Old Dec 10, 2009 | 07:21 PM
NCSU_05_FX4's Avatar
It puts extra wear on the ballasts and they can go bad early.
- NCSU
Old Dec 10, 2009 | 08:52 PM
OGmackPLRcool's Avatar
On my 03 harley if you push it once there is no flash and twice is when you get the flash/beep.
What kind of HID kit do you have? I wouldnt think it would hurt the ballast too much. Im pretty sure my Audi's lights flashed with the alarm and I never had a ballast go bad in 3 years...
Old Dec 10, 2009 | 09:19 PM
ChrisT's Avatar
I was wrong, when I hit the lock button once it will flash my lights. Twice and it flashed and sounds the horn once. Only information I can find about disabling the light flash is to reference a diagram and cut a wire. I'd rather take my chances with possibly shortening the life of an HID as opposed to cutting wires.
Interesting topic, though. I was curious if there was some trick to disable it. Kind of like the trick where you can see an RPM read out on a digital odometer on our F150's if you don't have a tach.
Old Dec 11, 2009 | 02:08 AM
01f1502wd's Avatar
^x2, mine does the same thing.
Old Dec 11, 2009 | 09:24 PM
scheetz31's Avatar
typical
whether i find a way to disable this feature or not i will still have gotten hids...never owned or will own a car without them...love them.
Old Dec 11, 2009 | 10:13 PM
Roadie's Avatar
The headlights on my 02 flash on when I shut the driver's door after I lock the doors with the door switch????
