4x4 not engaging
Old Nov 24, 2009 | 09:19 PM
riley_0521's Avatar
4x4 not engaging
ok here is what i got. I turn the **** in the cab and I hear a click at the transfer case but nothing. It will not engage. any ideas where to begin.
Old Nov 25, 2009 | 12:58 AM
Klitch's Avatar
check vacuum lines to your front diff, they run to a pair of solenoids behind ur battery up against the fire wall... check those lines make sure they are good and your solenoids pull vac when theyre suppose to.
thread that may help
https://www.f150online.com/forums/ot...um-system.html
Old Nov 25, 2009 | 01:06 AM
SSCULLY's Avatar
Please post the MY, trim level and if it is an ESOF or MSOF
Old Nov 27, 2009 | 12:47 PM
JMC's Avatar
JMC
25 Year Member
Does the 4x4 indicator light turn on? Does it prove out at start up?
Lift and support the front of the truck so the front wheels are off the ground. Key on, engage 4x4 and try to turn the front drive shaft. If it turns it is a problem with the transfer case. If it doesn't it is a front axle engagement problem.
Old Nov 27, 2009 | 10:47 PM
Klitch's Avatar
If he hears the click but nothing happens he may be having the same problems im having.
series of clicks, lights up, no engagement, will not drop 4x4 light. just a guess. we'll wait for his reply
