Painted Driveshaft
Old Sep 13, 2009 | 06:41 PM
4wd150's Avatar
i was thinking of painting my diff too, but wasnt sure if a white diff cover would look good
Old Sep 13, 2009 | 06:45 PM
b2therad's Avatar
I think it would. It would bring more attention to it for sure. Good luck keeping it clean though.
Old Sep 13, 2009 | 08:00 PM
SkyBound85's Avatar
i think i'm going to paint my rear drivetrain flat black instead of gloss black. i'm thinking of sanding off the surface rust and just a quick coat of flat black rust paint. sound ok?
Old Sep 13, 2009 | 08:06 PM
b2therad's Avatar
That would work. Just make sure to scuff up the surface of it up to get that rust off. I would use rustoleum.
Old Sep 13, 2009 | 08:14 PM
WowGuyF150's Avatar
So theres well enough clearance to just lay under the truck and shoot the paint on the driveshaft?
Old Sep 13, 2009 | 08:21 PM
4.2trimble's Avatar
guys id becarefull.
Driveshaft shops around here dont recommend painting the driveshaft unless you do it before balancing. They say paint can make it out of balance enough to tell while driving, and besides vibrations an unbalanced driveshaft can cause some problems with pinion seals and such.
Im not the only one thats been told that around here either so im gonna believe them.
Old Sep 13, 2009 | 08:41 PM
1bad86vmax's Avatar
I would use Por-15 (Black) . I love the stuff , it's the most durable paint i've ever seen . And you can paint right over rust .
Old Sep 13, 2009 | 10:35 PM
4x4wolf's Avatar
Unbalancing is also why I didn't use primer thought it would be a little lighter. And yeah there is enough room to crawl around under there but it gets a little tight on the driver side next to the gas tank
Old Sep 13, 2009 | 11:22 PM
Fire604's Avatar
I've wondered about that, too. In fact, that's the only reason I didn't use POR-15 on it when I did my rear axle.
Old Sep 14, 2009 | 04:57 AM
WowGuyF150's Avatar
I would think that the weight difference would be minute. If the paint can throw off the balance, then how about all that rust in sporatic areas?
Old Sep 14, 2009 | 12:47 PM
ChrisT's Avatar
Hmm, I guess this is one benefit to having an aluminum drive shaft. Mine still looks about the same as it did 7 years ago. I am liking the idea of painting my diff cover\axle and such. With a 6" lift I really don't have any excuse, I can almost sit Indian style under there. (exaggeration, but there is a ton of room to work).
Old Sep 21, 2009 | 10:57 PM
4x4wolf's Avatar
Part II Painted the Rear End
Before
After
After from the front
Old Sep 21, 2009 | 10:59 PM
thejake1989's Avatar
now you gotta do the frame haha. looks good man. glad i have an aluminum drive shaft and dont have to worry about it
Old Sep 21, 2009 | 11:02 PM
4x4wolf's Avatar
Frame is the next thing on my list to do, lucky you have a aluminum one
Old Sep 21, 2009 | 11:03 PM
gonna take the body and bed off? if you dont already have one id do a body lift while every thing is off
