Photo request, 97-03 w/ 35"
Old Aug 4, 2009 | 10:28 PM
wandell's Avatar
Yeah, 35x12.50's will fit at stock height using the OEM wheels, but they look a lot better with at least a body lift.
Old Aug 4, 2009 | 11:45 PM
b2therad's Avatar
Originally Posted by 4x4wolf
285's 33 inchers, 315's are just a bit under 35
The difference between 285 and 315 has nothing to do with diameter. A larger first number means that the tire is going to be wider. 285/75/ r16's are more narrow than 315's. Changing the second number to a larger number would increase the diameter.
Old Aug 4, 2009 | 11:59 PM
Dnasty777's Avatar
Sorry b2therad but thats not completely true. It is an aspect ratio, which means that if you increase either number both the width and height are going to change. The first number is in fact width but it is the second number that is the ratio.
Old Aug 5, 2009 | 12:51 AM
RathF150's Avatar
Member TylerFX4's truck, says he has 35's with just t-bars cranked
here's the link to a pic
https://www.f150online.com/forums/me...1-untitled.jpg
Old Aug 5, 2009 | 08:30 AM
jbrew's Avatar
That looks pretty good
Old Aug 5, 2009 | 12:24 PM
TylerFX4's Avatar
im runnin 315/70/17s which is a 34.5/12.4 on just keys
Old Aug 5, 2009 | 12:30 PM
TylerFX4's Avatar
thanks man
Old Aug 5, 2009 | 12:33 PM
Dnasty777's Avatar
Hmm.. That looks better than I thought it would.
Old Aug 5, 2009 | 12:37 PM
TylerFX4's Avatar
yea its a lift on a budget all i have is 900 in wheels and tires
Old Aug 5, 2009 | 12:42 PM
FX41's Avatar
That looks really good Tyler.
Old Aug 5, 2009 | 01:07 PM
jbrew's Avatar
Mannn, I need some Black rims lol.
Can you still get around 14 mpg with those tires Tyler? I get about 16 now on the e-way on cruise @ 76 mph.
What would I loose with those, just a couple miles per gallon maybe?
Old Aug 5, 2009 | 10:01 PM
wandell's Avatar
With a stock 5.4 engine, 3.55 gears and 35 inch tires I average 13 MPG combined city/highway.
Old Aug 5, 2009 | 11:20 PM
31 YNOT's Avatar
right and wrong. the 2nd number is an aspect ratio of the first number. so if you have a 285/75R16 so the side wall is 75% of the 285. it will be shorter than a 315/75R16 which has a side wall of 75% of the 315
Old Aug 5, 2009 | 11:46 PM
1clean42's Avatar
^^check your sfx thread, I posted you a sig on there
Old Aug 6, 2009 | 12:54 AM
TylerFX4's Avatar
i honestly couldnt tell ya i dont really pay much attention to mpg
