LED tail lights
LEDs in any turn signal (front or back, left or right) need a resistor or you can buy an LED flasher module to replace the one under the dash
Couldn't I just get a different flasher and not worry about the resistors?
In all honesty, I will put regular bulbs back in before I go through all the B/S of doing that to every light
But my problem is not a flasher... My front signals, and rear tails are regular bulbs... It is the reverse lights that are LED, along with the cargo lights & 3rd brake light (Factory L)
cyclone, you can buy a different flasher and just replace your stock one instead of the resistor route.
as for your problem, are you saying your CC isnt wokring? you have an L brakelight with LEDs in the cargo lamps?
(3rd for you non-Fordians) with a set of LED bulbs in the cargo lights.... And my reverse lights are LED
those LED cargo lamps may be the problem. try switching them back to stock and see what happens
Actually, come to think about it. I need to take them out anyways because they are not working anymore
And I noticed the other day the screws were rusted looking. So I need to change them out for some stainless ones. Maybe that will be a tomorrow project when I get off work... Wish I woulda known this about 12 hours ago. I had today off and did not do a damn thing!
This applies to 05 and newer vehicles. Can't determine which you have since you have 03 in your profile and 09 in the sign. Fix that.
here, read this: https://www.f150online.com/forums/el...ml#post3824778
I just know something isn't right somewhere.
I actually had the "L" set up quite awhile before the city idiots touched my truck LOL
Maybe your problem stems from when you wired your truck up wrong & caught it on fire
Touche good sir!
