Holy fuel filter...
jbrew, both scrissor tools you have listed are the ones I tried with no luck. The first one, which is the 3/8 and 5/16 one is still too big for the outlet line fitting. The bigger tool in your last pic I got first, it even said "Ford AC line and Fuel line tool".. but it was only worth as much as the plastic it came in.
I'll try some PB blast out or something similar tomorrow and let you guys know.
Yea, then you definitly have problems lol. The plastic tool that's shaped like a triangle NEVER worked for me. The plastic round ones SHOULD work (last pic).
I dunno know if I would use PB Blaster, there is an O-ring in their. WD40 or SEAFOAM Deep Creep would be best.
Steve83 has a nice diagram w/instructions here -
http://www.supermotors.net/registry/media/497461_1
The troubles I had in removing my fuel filter were the deciding factor in whether I would drop the tank or pull the bed when my fuel pump went bad. I pulled the bed so I could see what I was doing when removing the fuel lines.
When I change the fuel pump sock,-
I just lower the tank enough to pull the pump so I don't have to disconnect all that other junk on top,- that crap breaks to easy lol. It goes pretty quick after you've done it once or twice. But yea, I don't have a problem with the filter on the 98.
If I had a couple IRAX hoists, -pulling the bed would be cool. One day I will
I was for sure the smaller scissors tool was gonna work, but the metal is just too thick on it. I have some silicone spray i'll try first, then WD40 if that doesn't do it. The plastic ones look similar to the ones in the picture, just color-coated like the diagram and instructions talk about.
I spray PB blaster in both ends and turn he filter a few turns. Once you get the filter off take your plastic tool and put it on the end of the filter. If the locking ridge is larger in diameter than that of the tool you will never get it off. The removal tool has to be of the same diameter or slightly larger than that ridge. Cheap filters do not spec out as well as the brand names and the ridge may be larger than the tool. I would suggest taking your removal tool to the store when purchasing your next filter.
I rented one from AutoZone and it took me about 30 minutes one each side. I got it done (bending the old filter in the process) and brought the tool back the next day the lady looked at me and asked: "you did that already? usually people rent these all week trying to get it out!"
