fuel pump?
Might just have been a bad one. I've got 43k miles on a 2002 without a problem.
About the only thing I can say that has gone bad is the front pads @29k. Everything else was just not the way I liked it.
I'm doing a master cylinder, when the Sun moves behind the trees today.
I can't complain, because it has 198,000 miles on it. But, it does amaze me, that I haven't put a fuel pump on it yet. I attribute that to not using cheap gas stations.
The windshield wipers have quit on this one, I hope it's the electric motor, and not an electrical problem. I'll find that out after while also.
Nice trucks. The biggest complaint on a fuel pump I've seen is it not flowing enough fuel under a modified engine. Put a better pump in and you're good to go.
Thanks. I do love the white one, it has a pearl paint job, the red one is one I put together for my Son.
I wonder what happened to the OP?
I believe the problem with his pump is the lack of use, or just a bad pump. Things work longer when they are used regularly.
If it wasn't for loving the paint that came with my truck I would love to change it. As it is it just needs some ghost flames or silver airbrush high lighting. On the fuel pump did u reset the motion switch and check fuses? If it does run it could just need a fuel system cleaner from sitting where it can collect water.
Uh oh. I didn't know it had a motion switch. I didn't bump anything or stop suddenly, I wouldn't think the switch would trip without that happening.
I may have left myself open to a ripoff.
I did take it to a Ford dealer instead of some local garage, so i'm counting on the dealer being generally the more honest of the two. And I did insist on getting the defective pump when they finish.
Naaaa....I drove this truck offroad all over the desert, hitting bumps & holes and it never tripped.
Dealer said he was ordering a new pump, so i know i'll have the used one in my hand to investigate.
And i wouldn't trust any local garage in this area - we're too close to Georgia.
