electrical poltergeist
Old Apr 10, 2009 | 11:21 AM
ridiculously_ne's Avatar
posting for friend...
02 F150, package unknown, assuming XLT
symptoms:
1. when it rains the truck will not start unless its been running and warm.
2. rain can kill the battery overnight.
3. when driving in the rain (started dry) the radio, windshield wipers, etc. can shut off. he can usually shut off and restart and it resolves the problem.
4. when shutting off in the rain, the heat usually comes on full blast. and the radio might turn on if it was off.
i was hoping this might be a simple seal or corroded wire and that someone has run into a similar situation before. he just hasnt taken it to a mechanice yet, and im pretty sure hes goign to have to. thought i would check here first.
thanks!
Old Apr 10, 2009 | 11:33 AM
efuehrin's Avatar
Maybe it's really a poltergeist!
Edit: That hates rain!
Old Apr 10, 2009 | 11:46 AM
he needs to get over it or go inside then, because jacking with the truck isnt going to make it stop. hes (or she) acting very childish!
Old Apr 10, 2009 | 12:47 PM
Veteran: Army
check the cables that run to the starter there'e probably water build up in there
also check the cables to the battery
Old Apr 12, 2009 | 08:11 AM
justusinfla's Avatar
symptoms:
thanks!
Sounds like a leaking windshield that is allowing water to reach the GEM (general electronics module). The GEM is the computer that controls all electronics other than the engine. I've had the problem with my 97, and Ford told me it they are familar with the problem. Good luck!
Old Apr 13, 2009 | 11:25 AM
thanks man! we weer wondering about that this weekend. is the GEM in the engine bay or behind the firewall?
thanks
Old Apr 17, 2009 | 04:29 PM
bump
Old Apr 18, 2009 | 03:38 PM
It's inside the truck behind the dash somewhere.
