Oil filter - can't get it off
Old Mar 14, 2009 | 07:40 PM
mo500's Avatar
I just purchased this F150 super crew FX 4X4. I was going to change oil & filter today. The person that designed the placement of the filter is not my best friend. The last fellow that changed the filter used his muscle to tighten it. To get it OFF don't I turn it counterclockwise? Also what type of tool makes it easier to get the filter off? ......THANKS in advance for your help!!! By the way it is the 5.4 liter engine.
Old Mar 14, 2009 | 08:01 PM
FF/PM_L1563's Avatar
Yes, counterclockwise. Go to sears or some other hardware store and get yourself a oil filter wrench that has at least 3 "jaws" on it.
http://www.sears.com/shc/s/p_10153_1...+filter+wrench
Old Mar 14, 2009 | 08:02 PM
See if this link has any help.
https://www.f150online.com/forums/v8...oil+filter+off
Old Mar 14, 2009 | 08:13 PM
mo500's Avatar
Oil Filter - can't get it off
I just purchased this '03 F150 Super Crew FX 4X4 - 5.4 V8. The filter must have been put on by superman. Does it turn counterclock to get it off? And what does it take besides my hand power to make this an easier job??? ....Thanks for your help!!!!!!!!!!
Old Mar 14, 2009 | 08:24 PM
JNC995's Avatar
Lefty loosey; Righty tighty. Try a strap wrench. The position of the filter makes it hard to get off by hand.
Old Mar 14, 2009 | 08:26 PM
Hunt&Fish's Avatar
Don't know if it's in the same spot as my 2000, but a cap style "wrench" (the cap fits on the end of the filter) makes removal pretty easy. I use a stubby ratchet because of tight quarters. If you have to buy a cap style wrench, see what brand filter is on the truck now, and do a trial fit at the store. If you have the room, a band style filter wrench will do wonders over using your hand too. Righty tighty, lefty loosie.
Old Mar 14, 2009 | 08:40 PM
Here is some discussion.
Old Mar 14, 2009 | 08:42 PM
thecause17's Avatar
This is what I use on my truck also. Even though I only put my filters on hand tight, more often than not, they are too tight to get back off by hand later. Just got the auto parts store, find the filter for your truck, and try the wrenches until you find one that fits.
Old Mar 14, 2009 | 09:00 PM
MAD IN NC's Avatar
I just went through the same ordeal on a new truck I feel for ya!
https://www.f150online.com/forums/v8...what-pita.html
Just picked up on of these from E-bay (from Matco) for $10.49. Like the design as the more you crank the tighter it gets! .... BTW - I ruined two other types of wrenches last time. Hopefully it won't be three!
Old Mar 14, 2009 | 11:31 PM
ErikShockey's Avatar
This is similar to the filter wrench i use, picked mine up at Sears for about 12 dollars.
Old Mar 14, 2009 | 11:55 PM
ive got a strap wrench that i love to use, same principle, it gets tighter the more you push it
Old Mar 15, 2009 | 02:13 AM
jbrew's Avatar
Dang!! Mine goes on by hand and comes off by hand
Old Mar 15, 2009 | 09:52 AM
cH1rO420's Avatar
Amen to that
I think you'll need your hand power even with all those tools and you'll still be having to use your hand .
Old Mar 15, 2009 | 10:57 AM
Screw-Me-05's Avatar
X3........... And always lube the O ring so it doesn't stick to the housing and always check for the old O ring came off so there is no leaks on that clean driveway.
Old Mar 15, 2009 | 11:20 AM
jbrew's Avatar
Wish I could say that about my fuel filter, - specially when right spring de-twanger gets misplaced
________________________________________________
But assfarass oil filter extraction, these are a $@!&*$@%%(_%^#!!! to rewind -
--------------------------------------------(circumvent^^proof)--------------
BUT THESE -
^^^^^^ -R Cake
Last edited by jbrew; Mar 15, 2009 at 11:30 AM. Reason: Needed some serious editing
